Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2015-2018 Chevrolet Colorado LED Upgrade Bulb Size Guide
Old Dec 21, 2023 | 10:12 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default 2015-2018 Chevrolet Colorado LED Upgrade Bulb Size Guide
Looking for the ultimate LED upgrade recipe for your Chevrolet Colorado? This comprehensive guide has all the ingredients for illumination success. The key is identifying your Colorado's OEM halogen bulb sizes, as the correct LED matches ensure a smooth plug-and-play install. We've compiled a handy bulb size chart covering all halogen lights across 2015-2018 Chevy Colorado. With the precise LED bulb sizes that align with your halogens, you have the perfect formula to give your truck a stunning LED makeover. Follow our tips to cook up an LED upgrade that takes your Colorado's lighting capabilities from drab to fab.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: 5202/2504
3rd Brake Light: T15/921/912
Back Up Light: T15/921/912
Front Side Marker Light: T10/168/2825
Cargo Light: T15/921/912
License Plate Light: T10/168/2825
Front Turn Signal Light: 7443/7444
You can try Lasfit LED bulbs on your Chevy Colorado. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam: LCplus H11-N
LCplus series are designed as small as it can to fit the assembly with bulb hole off the center. LC plus is one of the smallest LED lights on the market, with built-in driver which can perfectly fit most vehicles without installation issues. Plug and Play. Truly 50W/Set, 5000LM/Set. Let you experience brightness far beyond halogen bulbs. 360° Adjustable Beam Pattern.
Not Only The Smallest, But Also More Stable! The led bulb with the all-aviation aluminum body, hydraulic fan and built-in intelligent IC and temperature control system can perfectly solve the problem of light decay and dead lamp caused by the highest temperature of LED car light to ensures it will last longer.
High Beam: LAplus 9005
We would like to recommend Lasfit LAplus series 9005 LED bulbs to work on Colorado. 30W, 3000LM per bulb, 6000K bright white. They are built without an external driver directly plug and play. New cooling system with a unique ball-bearing fan for heat dissipation, and upgraded LED clip to ensure ultra-high luminous efficiency.
Fog Light: LDplus 5202(Switchback)
The LDplus series is a special line of bulbs that can switch between white and yellow dual-color lighting. It is often used as fog lights to adapt to diverse weather conditions.
3000LM per bulb, 6000K for white light and 3000K for the yellow light. Strong penetrability in foggy day, snowy day, rainy day, and haze weather. The white light starts firstly, with a simple on-off-on toggle of your fog light switch to change the light from 6000K cool white to 3000K warm yellow light. Dual color fog lights can cope with more complex driving scenarios, without the need for more modifications. One bulb, two experiences, this will give you an extraordinary driving experience.
Front Turn Signal Light: T-7443D-CK(Switchback)
Each bulb has 32pcs SMD 3030 LED chips (24pcs for amber, 8pcs for white). Built-in anti hyper flash Canbus system, specially designed for turn signals. Light up 6000K xenon white for parking lights or daytime running lights (DRL); 3000K flash amber for turn signal lights. Totally refreshed the tired and dim-looking lights with bright white DRLs and crisp amber turn signals. Intelligent Temperature Control System protects led bulbs against excessive current and overheating and ensures a longer lifespan.
Back Up Light & Cargo Light: L-T15(White)
1400LM/set. The bulbs redesign distribute light in perfect direction, most notably improving the side and rear-ward spread. Clearly notice of the object as you back up and offer an excellent brightness inside the vehicle! Plug and play design.
3rd Brake Light: L-T15R (red)
1400LM/set, brilliant red. Lasfit uses high power 3030 SMD LED chip to produce peak brightness output and built-in Constant Current IC driver to ensures reliability. Equipped with CANBUS system, will not cause "lamp out" errors. Plug and play design. Depending on the position and function, you should choose red for 3rd brake lights.
Front Side Marker Light: L-T10A(amber)
800LM/set, much brighter than OEM halogen bulbs. It's necessary and easy to achieve to add a modern appearance to your truck by replacing stock halogen bulbs with this LED bulbs. No need any modification, just for plug and play installation.
License Plate Light: L-T10(white)
800LM/set, 6000K pure white. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Canbus pass by error check for 2015-2018 Chevrolet Colorado trucks. Non-polarity design, no need any modification, just for plug and play installation.
LASFIT
Dec 20, 2023 10:24 PM
LASFIT
Nov 22, 2023 9:53 PM
LASFIT
Colorado
Nov 21, 2023 12:45 AM
LASFIT
Sep 5, 2023 9:30 PM
