I just purchased a 2022 Colorado and want to put different tires and wheels on it. I am looking for suggestions in regard to tire sizes even wheel ideas.
It is diffucult to answer your question when you do not state why you want to replace new? tires and wheels. If you change the diamerer you will have an inaccurate speedometer reading. If you go wider you will loose traction in ice and snow. If you go with a larger diameter wheel and a short (rubber band) tire you will get a harder ride. Do you need highway tires, mudd tires, ice tires or all season tires?
i just purchased a 2022 colorado and want to put different tires and wheels on it. I am looking for suggestions in regard to tire sizes even wheel ideas.
Look At The Sticker On The Inside Of The Door.. DO NOT Let Some Mom And Pop Corner Tire Store Sell You Oversized Tires, I Use To Work At One..2 Months Later The Customers Would Come Back With Their Transmission Repair Bills .. Gear Ratio And Tire Size Are Researched.
I purchased the Raceline Shift wheels 17x9 +33 offset as we are very limited on wheels with the 6x120 bolt pattern. I have the Falcon Wildpeak 275x70x17 tires installed. I have a 2' leveling kit installed.
