removing rear cross member
I am doing a complete body of restoration on my 73 vette and i cant get my rear cross member off i have removed the bolts and tried a pry bar and still cant get it. Anything i am missing?
Welcome to the forum.
You might post in out sister forum in the C3 section: http://www.corvetteforums.com/forum/index.php Someone there should be able to answer your question. That's one thing that I haven't removed on mine. Is it possible that the rubber bushings are stuck to the frame? |
The bushings are stuck to the frame. Spray with PB Blaster and use a larger pry bar. I do this close to the floor with a floor jack under the center section. Good luck
| All times are GMT -5. The time now is 5:32 AM. |
