Cam question. Will my brakes work with this cam 78 chevy 350 stage 2 or so they say.
ENGINETECH ES179R Info
Stage 2 high performance. May not be computer compatible. Use hydraulic flat followers.050" Duration-222/222; Cam Lift-.298/.298; Lobe Center -110/118. Use high performance spring kit p/n VSA3 or ERV943 springs. Would this be better or worse? Stage 2 high performance. May not be computer compatible. Use hydraulic flat followers.050" Duration-214/224; Cam Lift-.295/.310; Lobe Center -107/117. Use high performance spring kit p/n VSA3 or ERV943 springs. both of these cost 80$ with lifters. |
