Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Cam question. Will my brakes work with this cam 78 chevy 350 stage 2 or so they say.
Old June 12th, 2018, 10:27 PM
Michael Grappin's Avatar
Question Cam question. Will my brakes work with this cam 78 chevy 350 stage 2 or so they say.
ENGINETECH ES179R Info
Stage 2 high performance. May not be computer compatible. Use hydraulic flat followers.050" Duration-222/222; Cam Lift-.298/.298; Lobe Center -110/118. Use high performance spring kit p/n VSA3 or ERV943 springs.
Would this be better or worse?
Stage 2 high performance. May not be computer compatible. Use hydraulic flat followers.050" Duration-214/224; Cam Lift-.295/.310; Lobe Center -107/117. Use high performance spring kit p/n VSA3 or ERV943 springs.
both of these cost 80$ with lifters.
