Accessory Power Outlet
My Accessory Power Outlet in the front and back seat does not work the one in rear hatch does. I have check all fuses all are good and i even replaced to make sure. I used a power checker and it said i have no current on the plug.
What year is your Equinox? Did you check the fuses in both the interior and underhood fuse blocks? The power outlet in the rear is probably on it's own fuse, but the other two probably share the same fuse.
2005 I checked all fuses my book only show fuse under hood it doesn't have a fuse for the plug on the inside fuse box I check that one to
Originally Posted by Kim Hodge
(Post 342383)
