How do install an auxiliary temperature gauge
2007 Equinox
My temp gauge is not working and I was going to just put in my own mechanical Temp gauge. Where do I put the Probe from the gauge, does it go in a port in the head, between a hose or where?? |
You don't want to remove the factory sensor because the engine won't work properly. So you would have to fashion some sort of hose adapter I guess. A piece of pipe to act as a coupler, with a hole drilled in it for your probe maybe. Sounds like a leak waiting to happen though. Maybe just cable tie it to a part of the water pump or thermostat. It won't be super accurate, but better than nothing.
🤷♂️are you sure it's the gauge that's not working? |
(Post 497046)
🤷♂️are you sure it's the gauge that's not working?Yes the gauge is not working it goes all the way around and sits on pegged. You can cycle key and get it back around but it does same thing. I've already changed out the coolant temp sensor and that didn't fix it. |
Originally Posted by BSUD
(Post 497051)
They actually make Temp gauges that go between the radiator hose. I just didn't know if it would be more accurate in a port somewhere.
No other ports I'm aware of.
(Post 497051)
It is possible that the stepper motor for the temp gauge is bad. There was a problem with them around that time period.
Originally Posted by oldchevy
(Post 497075)
