Chevrolet Equinox
Platform: Theta
U0107 No Start
Old Oct 15, 2014 | 5:24 PM
TomZilla's Avatar
Default U0107 No Start
Took it to the shop and they still couldn't figure it out yet, we replaced the throttle body (salvage), PCM (salvage). Still no-start issue. They checked sparks and fuel. Here's the background story:
It began 2 weeks ago, it wouldn't start, but after cranking 4 or 5 times, it started. I kept pressing the pedal while doing it.
It worked for a few days, then I drove to work at 9AM, and then by 5PM when I get out of work, it wouldn't start at all. It has code U0107. And had to be towed. Reduced Engine light comes on.
I cleaned the throttle body, and replaced the purge valve selenoid and PCM, worked for a day, then stopped working. So I unhooked the negative of the battery for about 20 minutes, and it worked, worked for a week. And then it stopped working again at Walmart parking lot. I let it sit there for about 3 hours, and got my buddy to come and give it a jump. Everytime I try to start on my own, it would not start, but with a jump, it will. Tried changing to a new Walmart battery that has CCA less than my car, it started the car for 2 times, but after that it didn't work anymore.
Error codes:
U0107
P0443
P1516
P2101
Anyone who solves this problem will personally receive $50 from me!
Old Oct 15, 2014 | 6:45 PM
From what I read of this bulletin you need software updating for the PCM, and if you used a salvaged PCM it to may have the old software...
Is the shop your using a certified dealership or no? a dealership should have access to this info and know how to check for the software update....
Or maybe you just need a ground strap...
File Type: pdf
Old Oct 15, 2014 | 7:37 PM
TomZilla's Avatar
Thanks for your reply. Does this apply to my vehicle? I couldn't find 2005 Equinox in the TSB you provided. I called the dealership and the guy answering the phone said the TSB doesn't seem to apply to my vehicle.
Can you also elaborate more on the ground strap?
The place I bought the used PCM provided this info for U0107:
U0107 - Throttle Actuator Control Serial Data Circuit Malfunction - With Automatic Transmission
1. Check for battery voltage at the TAC pin 7 Pink wire.
2. Check for a good ground at pin 15 of the TAC module.
3. Check the serial data wires between the TAC module pin 12 Orange/Black wire and pin 13 Dark Blue/White and the Powertrain Control Module (PCM) pin 14 and 15 for opens and/or shorts to ground.
But the big issue is, I have yet to locate the TAC module for my vehicle. I looked all over, Autozone, Oreillys, ebay, no listing for TAC module for my vehicle.
Also, what's crazy is... The U0107 code was set before I swapped to the "new" PCM. So the question I have is, why does that code pop up now if it needed software update? (shouldn't it popped up 3 years ago when I bought the vehicle?)
Old Oct 15, 2014 | 7:55 PM
You would be correct , it does not apply to your vehicle... I found your original post in the Tahoe Suburban section for TSB's and you had a redirecting thread and I did not see that it was the Equinox section....
The only thing I find for the 2005 Eq is this one...
Be sure you are clearing all the old DTC's and that your battery is fully charged...
Old Oct 15, 2014 | 8:22 PM
TomZilla's Avatar
Oh wow, that's fantastic info sir.
Also, the car is in the shop, should I provide this info to them, if so, what would be a good way without coming across as "doctoring it myself?"
Old Oct 15, 2014 | 8:26 PM
the throttle actuator control module is the "computer part" screwed into the throttle body.
This can be hard to diagnose even for professionals. If you have no luck take it to a dealer tech with gm global CAN training. Simple things you can take anywhere but sometimes you need dealer support to fix the tough stuff.
Old Oct 15, 2014 | 8:30 PM
TomZilla's Avatar
Also,... there's a link on that PDF about ""Testing for Intermittent Conditions and Poor Connections and Connector Repairs" do you have it?
Old Oct 15, 2014 | 9:26 PM
vtbigdog's Avatar
DTC Code: P0443
Description: Evaporative Emission System Purge Control Valve Circuit
Probable Causes:
Sensor or solenoid faulty
Connector terminal contact is damaged or corroded
Wire harness - Check harness for correct voltage, open, short to ground or short to voltage
Update control unit software - Check for the latest control unit update
Powertrain or Engine Control Module faulty
Vacuum leaks, damaged hoses or improper routing
EVAP system - Check fuel cap, canister, valves or components
DTC Code: P1516
Description: Electronic Throttle Module Throttle Pos
Probable Causes:
DTC Code: P2101
Description: Throttle Actuator Control Motor Circuit Range / Performance
Probable Causes:
bracca
Jul 12, 2009 6:14 PM
Thermool
Jun 20, 2009 6:41 PM
wildboy74ss
Apr 1, 2009 5:10 PM
izod
Feb 14, 2009 2:42 PM
