05 Equinox drags when starting and clock keeps resetting to 12:))
The past couple of days when I go to start my car (05 Equinox) it seems to drag and not want to turn over. Also, the clock on the radio keeps resetting to 12:00 every morning.
Does anyone have any ideas what it could be? Battery is new so I now it's not that.
Please help!!
Please help!!
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I cannot find any issues with the Equinox based on your description. If you would like to PM me your full name, phone number, VIN number, mileage and dealer you normally work with, I'd be happy to look into this further for you. I look forward to your response.
Louis
GM Customer Service
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
Louis
GM Customer Service
I suggest checking any cables which are power related ie. The negative cable. These could be something as simple as them being loose or it could be something big like a bad computer.
New User
Awaiting E-mail Confirmation
It sounds like a battery/electrical problem. The battery is responsible for powering the memory that keeps your time. I had a similar issue in my previous truck, a Chevrolet s10. I live in Minnesota so I chalked it up to it just being effected by the cold weather, until I got my battery checked and realized it was good. I would recommend checking your connections to the battery and making sure they're free of corrosion and on securely. The issue on mine was that the post on the negative terminal had gotten loose and didn't have a good connection.
Flyazzfly
May 12th, 2015 7:08 AM
srv3fender
August 31st, 2010 6:55 AM
stockneley
January 14th, 2009 11:04 AM
