09 Equinox PCV valve location????
Grahambp1978 (July 7th, 2021)
You are correct. My mistake. I would wonder if the valve cover could be cleaned with something like a carburetor/motor block/ or heads dip substance that we used to use in auto shop?
The orifice itself usually requires several alternating blasts of carb cleaner and compressed air to open it up. I’ve found that a good soaking with penetrating oil really helps soften the build up (also true for cleaning gasket surfaces).
If you’re cleaning it yourself (and aren’t in a hurry) there’s no reason not to do it. But in terms of shop labor cost in making sure the orifice and baffles are thoroughly clean, it’s cheaper for the customer to just pay for installing a new valve cover.
parentsmag
January 13th, 2010 8:57 AM
