2.4l - what to replace and inspect while engine is pulled?
2014 equinox with 2.4. Engine went, pulling one from a junkyard. Will inspect fluids, compression test, etc. As best I can beforehand.
Besides timing chain, guides, valve seals, and front and rear crank seals, what else should I replace or inspect? Of course the head gaskets, intake, exhaust, etc will be replaced with the above work.
from a TSB that was out apparently the pistons and/or rings would be replaced, but that ended with the 2013. Same issue with the 2014?
Gentlemqn Glen
Cobalt
June 27th, 2017 4:54 PM
