2005 Chevy Equinox - Headlight
Quick question regarding my headlight. I have the driver side headlight out. Took it to a place twice. Once got charged to replace it. It is still going out. They said if it happens again, they will have to replace the whole assembly. Now, its just low beams. Is it accurate that if the low beams are out, but the high beams work, that its a socket issue or just a bad bulb? It sounded like a bunch of crap to me, but figured I would ask.
Thanks a lot.
Thanks a lot.
That's not what I am getting at. I am specifically asking if these are two separate bulbs? The high beams work, the low beams do not. The suggestion by the repair place was I replace the socket or the assembly for the light itself, if the bulb is a single bulb, the only reason one would work and the other would not is because the low beam is blown... correct?
garyv990
February 11th, 2015 9:52 PM
Markgc1964
March 2nd, 2013 5:03 PM
