Chevrolet Equinox
Platform: Theta
2005 Equinox Radio/CD/Sound System
Old Dec 2, 2021 | 10:26 PM
  #11
AlexanderM's Avatar
Originally Posted by ruley73
The grille that you see on the rear right quarter panel isn't removable. You'll need to pull that panel off. Once you have access to the subwoofer enclosure, you should be able remove the driver itself. The OEM subwoofer is an 8" dual voice coil design. Each coil has a nominal impedance of 2 ohms. I'm unsure of the wattage rating, but 120 watts sounds about right.
So it just pulls off, no screws? Thank you!
Old Dec 3, 2021 | 8:41 AM
  #12
bearbait's Avatar
When I purchased my 2008 Nox LS new I noticed the radio was weak. I went to different stereo shops and all of them wanted to replace radio and speakers for $1000+. I contacted Crutchfield in California and they claimed changing the radio was not needed. I purchased a 350 w amp and 4 speakers for $350. I installed amp under rear seat and replaced the larger door speakers. I disconnected the small door speakers per their instructions. Was a bit of work but it sounds great. They provided all installation instructions and have a great customer support system. The only negative is the chimes and turn signals are a bit loud but you get used to it. A friend of mine stated it would have been easier to purchase a hearing aid!!
MNBenny
Aug 24, 2019 12:05 PM
Ruth Trinidad
Traverse
May 13, 2019 10:08 AM
randlls
Feb 20, 2018 9:34 AM
Citylimits
Aug 7, 2017 1:42 PM
