2006 Equinox Blend door(air temp door)
#21
get ready to replace the new door 5 years from now as the replacement doors are not updated.
it is not a safty issue as the mode (defrost) door is operational.
I agree over torquing is the causing the problem along with poor door design so don't crank the temp control to full hot or full cold.
the mode and recirc doors are the same design but never break due a common linkage that shares the stress.
unfortunatly, everyone thinks their problem should be fixed for free. If you win a class action judgment against gm for this; can you get Bill Gates to fix my broken computer?
#22
Jeremy
ASE Certified Tech
#23
This Job your about to take on will take alot of time and paitents, I had to fix mine 2 yrs ago and you have to remove the whole dash and the dash support in order to access your heater acuator blend door wich swithes from cold to ho, chevy said they would charge $4,500 So i said forget them and di it myself!!! If you have any questions email me @ newlook_inc@hotmail.com and put in the subject: (Accuator Blend Door) or I will not respond. Its not as bad as I thought but be prepared to have alot of tools and paitents and time!! Good Luck!
Jeremy
ASE Certified Tech
Jeremy
ASE Certified Tech
#24
Just found this site. Great info guys. My wife's 06 Equinox LT just developed this problem yesterday. Was working just fine that morning, then on the way home from work... no heat at all. Sounds exactly like what everyone is describing. For those who want to tackle this job themselves (as I am going to do) I found an AWESOME step-by-step write up with pics at this site:
How To Fix A No-Heat Problem In A 2006 Chevy Equinox - Removing Dashboard To Replace Air Blend Door
I hope its not a problem to post links to other sites. We do it on the Grand Prix site all the time. Just trying to help some fellow Chevy owners out.
#25
One mandatory step that is not mentioned is calibrating the HVAC actuators when you are finished. This probably would have prevented the writer's Service Engine Soon light from coming on.
To do this, start the vehicle then push the A/C and RECIRC buttons on the HVAC control module three times each, within two seconds of initial push. I believe this should work for all 2005-2009 Chevy Equinox/Pontiac Torrent.
- The A/C and RECIRC button LED's will flash while this calibration is taking place.
- The calibration will take anywhere between 10 to 30 seconds depending on battery voltage.
- The LEDs will quit flashing when the calibration is complete.
I've posted an excerpt from the FSM below.
2005-09 Equinox_Torrent_air-temp-actuator-replacement.pdf
#26
Just wanted all to know that Chevrolet is now covering this repair for 10 years and 120,000 miles. I just received a letter in the mail that this will be repaired free of charge at the dealer.
They will also reimburse you for the repair if you paid to have it done.
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
#28
I have similar problems with my 2007,,,, ac doesn't seem cold either,,,if I run ac ,,,and select recirc ,,,seems cooler...then auto switches to fresh air...back and forth,,,and ac light goes on and off ? Could this have to do with calibration of havoc actuators? (just bought e vehicle on Friday,,,only 42000 km on it and I already took it back ....unfortunately its a Nissan dealer...so not sure they will knw why to do about It?
#29
Yeah, I have 20K too many miles to have this covered under the facory recall. Local Chevy dealer's service dept. super told me too bad when I asked him about it. Damned hard to do this when we must have this vehicle working at any given time with 6 kids and 2 recent grandchildren. Bummer indeed!
Kentucky Kyle
Kentucky Kyle
#30
@kylerob70 sorry to hear that. My blend door just went out and mine has 112k just barely under the requirements. Its in the shop now getting diagnosed. If that is the problem then it will cover both diagnosis, parts and labor. You should try contacting Chevy thru the ChevroletDotCom website, and speak to a representative. They might be able to help you out. I hope someone post something on the main Thread page so others find out before spending the money since my dealer didn't tell me about any warranty/recall when I first took it there.
