2006 Equinox - horn / relay / intermittent beep problem
I have a 2006 Equinox that hates me. I've had an intermittent horn problem for a couple of years. I thought it was broken, but I tried replacing the horn relay. The horn still didn't work, but the key fob made the horn chirp when I locked the car. Then after driving a few miles, the horn started emitting short beeps at random. I had to pull over and remove the horn relay to make it stop. I can't afford to take it to a dealer, so I bought an aftermarket horn and button - not realizing that the aftermarket horn needed to be wired through the relay also. I can't get an inspection sticker until I get the thing fixed. Has anyone had similar problems? Thanks in advance!
2005-2006_Equinox_Horn_Wiring_diagram.pdf
