2006 V6 equinox no heat
I have a problem with no heat replaced the heater core and the blend door now I have no heat one heater hose is hot and the other hose is cold so there must no be water flowing through heater core but I don't know why. I've tried to bleed the system several times and thought I had it. any ideas?
broken temp control blend doors inthe hvac case are common....check to see if the door is moving when the temp control is changed.
