2007 Chev Equinox
#11
Here's your answer. Your battery is probably bad. If the vehicle is/was jump started correctly, no fuses should be blown. FWIW we just had to replace our battery toward the end of last winter. Also, to anyone reading this, I strongly suggest only replacing the battery with an AC Delco 47-7YR. It is the same as the OEM battery and is the only one with a 650CCA rating. All of the other group 47-size batteries have 590CCA (or less) ratings. These others may work fine, but probably will not last as long.
#12
I had my battery tested and it is fine. I replaced #4 fuse in the passenger side grouping and it was fine. My hatch still will not open. I noticed it will not unlock or lock with the FOB. I am assuming my latch mechanism is stuck. This is just another problem with this vehicle that is just pure headache.
#13
See this thread for more info and help troubleshooting.
chicken_buster
70
April 8th, 2014 3:18 PM
bentwrench
August 25th, 2011 5:52 PM
MikeyJ92280
January 7th, 2009 5:15 PM
CHRISSC
February 22nd, 2008 11:39 AM
