2007 Equinox
I have a 2007 Equinox. I had a bad left front wheel bearing. Changed that with no issues. Noise up front stopped. But now when I press the brakes it shakes. I removed the wheel and checked everything. All seemed ok. Why the shake?
You should check the lateral run out on your rotor.. The bad bearing couldve cause uneven wear pattern on the brake rotor. Causing brake pulsation.
