2008 Chevy Equinox-Moisture in passenger headlamp unit
I’ve had moisture in my passenger headlamp unit for quite a while. I remember this having started after I had incorrectly installed the side light bulb and it was not seated in the housing.
Recently I decided to investigate and watched a few YouTube videos on removing the moisture.. On opening the unit I found ( not visible externally) about 50 ml of water stuck at the bottom which fell out from the headlamp opening. The sealing does not appear damaged. Most YouTube videos talk about vet tubes and drain holes.I observed no vent holes/drain holes in the headlamp unit.
After pulling out all of the moisture using a Vacuum in the sidelight port. It was completely dry. I reinstalled the unit and 2 days later there is moisture again in the headlamp.
Can someone help me with their experiences in eliminating this moisture
traceysmine@gmail.com
December 31st, 2018 5:00 PM
