2009 Chevy Traverse A/C Diagram
I need info on how to R&R the A/C compressor> And a schematic of the A/C system. Hello I'm kinda working on the Vehical like RIGHT NOW. so I would like a response
recover the refrigerant
-remove the drivebelt
-remove the r/f wheel and fender liner
-disconnect the compressor clutch connector
-disconnect suction and discharge lines
-remove the compressor bolts and compressor
-compressor oil balancing is required
-accumulator or receiver drier should be replaced if the compressor detonated or you had a system leak
