2009 Equinox Issues
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
Love my car. Got it used in Feb2015. My 2009 Equinox has 56700 miles. AC compressor keeps cycling off and on when supposed to be on. Son tried to recharge AC and it cycled off. He could not get it to take full charge with this issue. It gets warmer in temp when shuts down. Blowing air just not cool air. What could it be? Approximate cost? Single mom-not a lot of money. Trying to learn auto things to keep from getting ripped off. Service traction control light came on right after I got vehicle and dealership said was not covered. What does this cost to repair? I have it off right now. Also have issue with key getting stuck in ignition when car is off and in park. Have to wait till hear click and then take key out. Why and how to fix please? I hear a lot about this being an issue but people are opting to just deal with it. Last few days it has been happening a lot and I am getting very frustrated. It is starting to look like I bought a money pit here. Only had the car since Feb 2015. Can someone help me please? Thank you.
Unlike many other vehicles, is it actually normal for the A/C compressor on the Equinox to cycle on/off under the right conditions. The evaporator core temp is monitored with a sensor. When it's temperature drops too low, the A/C compressor is temporarily disengaged until the air blowing through the evaporator core warms it again; usually about 10-20 seconds.
Are you getting both the SERVICE STABILITRAK and SERVICE TRACTION CONTROL messages?
Is your ABS warning light on?
Which engine does your Equinox have - 3.4L/3400 or DOHC 3.6L?
Is your check engine light on?
This is usually caused by a bad Brake Transmission Shift Interlock (BTSI) Solenoid located under the shift lever. Sometimes jamming the shift lever into park helps free it up, but sometimes not. You will need to disassemble the console to inspect/replace it. It is part number 15270327 for all 2007-2009 Equinox/Torrent and is only available from a dealership for about $30.
I am getting the service traction control message. No ABS warning lights. No check engine lights either. It is the 3.4 6 cylinder motor. On the key issue- I tried jamming the shifter in case something was stuck in there from previous owner. I got the instructions and followed them. It did not work. I will have to have dealer fix that. But thanks for the info. I really appreciate the help. I am really learning a lot and I like what I am learning. I feel more informed so thank you for your help. Let me know if there is another question to help me figure this out on traction control. The ac issue will have to be checked out by dealer.
Macha_nick
November 16th, 2013 1:28 PM
