2010 Equinox tail light assembly loss of power.
When my turn signal started blinking very fast, I checked the lights. Sure enough, the drivers' side bulb was out. I replaced the bulb with the recommended bulb (identical to what I took out) and it worked great - for 1 day! Then it started again, but the problem got worse! Now I can see a faint glow on the reverse light and side lamp and tail lamp, but no significant tail lights, no brake or turn signal and no significant back-up light. The whole assembly seems to be affected. I've checked the fuses (all good), the bulbs are all fine, and the wiring harness has no evidence of problems. Suggestions?
