2012 2.4 Equinox rough run/idle freezeframe and codes
I have the 2012 Equinox with the 2.4. I've been having an idle issue that over a couple of months has progressed from slightly rough idle, to stalling and lurching. Engine throws P0106 and P0108, which both come back as MAP codes. I have replaced the MAP twice since october (replaced, when the code came back I returned the part for the warranty and put a second on). The codes persist. I pulled freeze-frame data but am not super familiar with this info and was hoping someone could help me figure it out.
DTC: P0106
FuelSys1: CL
FuelSys2: N/A
Load PCT: 100
ETC: 45 c
SHRTFT1: -.08
LONGFT1: 14.1
FRP (KPA): 303
MAP (KPA): 0
RPM: 2446
VSS: 42 KPH
SPARKADV: 17
IAT : 22C
MAF (G/S): 41.6
TP%:41.6
AIRSTAT: OFF
RUNTM:111
FRP (KPA): 10350.0
EVAPPCT: 0.0
FLI: 60.4%
WARM_UPS: 0
CLR_DIST: 9KM
EVAP_VP (PA): 6
BARO: 96 KPA
CATEMP11: 735 c
VPWR (V): 14.69
LOAD_ABS: 70%
EQ_RAT: .999
TP_R: 31.4%
AAT: 20 c
TP_B: 41.6%
APP_D: 38.8%
APP_E: 18.8%
TAC_PCT: 42.7
DTC: P0106
FuelSys1: CL
FuelSys2: N/A
Load PCT: 100
ETC: 45 c
SHRTFT1: -.08
LONGFT1: 14.1
FRP (KPA): 303
MAP (KPA): 0
RPM: 2446
VSS: 42 KPH
SPARKADV: 17
IAT : 22C
MAF (G/S): 41.6
TP%:41.6
AIRSTAT: OFF
RUNTM:111
FRP (KPA): 10350.0
EVAPPCT: 0.0
FLI: 60.4%
WARM_UPS: 0
CLR_DIST: 9KM
EVAP_VP (PA): 6
BARO: 96 KPA
CATEMP11: 735 c
VPWR (V): 14.69
LOAD_ABS: 70%
EQ_RAT: .999
TP_R: 31.4%
AAT: 20 c
TP_B: 41.6%
APP_D: 38.8%
APP_E: 18.8%
TAC_PCT: 42.7
