2012 Equinox leaky moonroof
I have a 2012 Chevy equinox and the moonroof leaks from the passenger side. I watched a bunch of videos and posts online but everything people
say should be there is not on my car. I took the hardware off the roof panel to see the underside of the moonroof and I do not see any drainage tubes. Pulled the side panels off the passenger side and again no tubes. Is there
sone thing I am missing because I have been trying for weeks to figure this out. Thanks
did you try a web search? These were the first search results for me ...
Yeah I thought I put that in the post the videos that you posted and what I have seen do not match what my car has. For some reason I do not see any tubes coming from the moonroof on any side
https://www.youtube.com/watch?v=AQAcPspFd_M
https://www.youtube.com/watch?v=CG_pBZ58WWk
It's possible that your sunroof is aftermarket and the installer didn't install the drain tubes even though they are required. There's no such thing as a power sunroof that doesn't leak. They all have water mitigation (catch pans and drain tubes) specifically because of this. Webasto and ASC (American Sunroof Corporation) are the most popular aftermarket sunroof brands. An easy way to tell if your sunroof is aftermarket is to see if a brand is stamped on the underside of the glass in the rear section of the pane. Another way to tell is to look at the OEM sunroof switch and see if yours matches what you see and is in the same location.
Equinox 2012 4 cylinder awd. Lt. what a piece of junk!!! Windshield wiper motor $400. Leak from roof. Who knows how much?? Brakes are ****. Exhaust system is ****. Columns on either side in front so damn wide they block my vision( outside mirrors are NOT electric either. AC super noisy😖back sets don’t fold FLAT why not????? Wish I never bought this garbage won’t ever buy Chevrolet again and this is my 4th Chevy car
