2014 2.4 4cyl P2269 Code Water in fuel system
Hello - has anyone had a p2269 code on their Chevy Equinox (2014 2.4)? Says a water in fuel system issue. How did you diagnose the issue to see if it was bad gas, moister leak somewhere or bad sensor? Anyone have a picture of where the sensor is located? Thanks
Have you used "Heat' Additive to get the water out? Cheap gas stations are notorious for this. Some A-hole might have put some water in your tank too.
