Chevrolet Equinox
Platform: Theta
2016-2017 Chevrolet Equinox LED Upgrade Bulb Size Guide
Old Jan 2, 2024 | 8:33 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default 2016-2017 Chevrolet Equinox LED Upgrade Bulb Size Guide
Seeking the ultimate recipe for upgrading your Chevrolet Equinox to LED? This all-inclusive guide has everything you need for an illuminating success story. The crucial step is identifying your Equinox's OEM halogen bulb sizes, as the correct LED matches are the key to a smooth and hassle-free installation. Our meticulously compiled bulb size chart covers all halogen lights spanning from 2016 to 2017 for the Chevy Equinox. With the precise LED bulb sizes that align perfectly with your existing halogens, you have the perfect formula to give your truck a stunning LED makeover. Follow our tried-and-tested techniques to cook up an LED upgrade that will take your Equinox's lighting capabilities from ordinary to extraordinary.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: H8
Front Turn Signal Light: 7443/7444
Front Side Marker Light: T10/168/2825
License Plate Light: T10/168/2825
Interior Door Light: T10/168/2825
Back Up Light: T15/921/912
Rear Side Marker Light: T10/168/2825
Map Light: T10/168/2825
Dome Light: T10/168/2825
Trunk Light: T10/168/2825
Vanity Mirror Light: 31MM/ DE3175/ 6612F
You can try Lasfit LED bulbs on your Chevy Equinox. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam: LAplus H11
We would like to recommend Lasfit LAplus series H11 LED bulbs for your Low Beam Light. LAplus H11 LED bulbs are much brighter than halogen, 30W, 6000LM per bulb, 6000K bright white. New cooling system with a unique ball-bearing fan for heat dissipation makes the bulbs more lifespan.
High Beam: LAplus 9005
We would like to recommend Lasfit LAplus series 9005 LED bulbs to work on Equinox. 30W, 3000LM per bulb, 6000K bright white. They are built without an external driver directly plug and play. New cooling system with a unique ball-bearing fan for heat dissipation, and upgraded LED clip to ensure ultra-high luminous efficiency.
Fog Light: LDplus H11(Switchback)
The LDplus series is a special line of bulbs that can switch between white and yellow dual-color lighting. It is often used as fog lights to adapt to diverse weather conditions.
3000LM per bulb, 6000K for white light and 3000K for the yellow light. Strong penetrability in foggy day, snowy day, rainy day, and haze weather. The white light starts firstly, with a simple on-off-on toggle of your fog light switch to change the light from 6000K cool white to 3000K warm yellow light. Dual color fog lights can cope with more complex driving scenarios, without the need for more modifications. One bulb, two experiences, this will give you an extraordinary driving experience.
Front Turn Signal Light: T-7443D-CK(Switchback)
Each bulb has 32pcs SMD 3030 LED chips (24pcs for amber, 8pcs for white). Built-in anti hyper flash Canbus system, specially designed for turn signals. Light up 6000K xenon white for parking lights or daytime running lights (DRL); 3000K flash amber for turn signal lights. Totally refreshed the tired and dim-looking lights with bright white DRLs and crisp amber turn signals. Intelligent Temperature Control System protects led bulbs against excessive current and overheating and ensures a longer lifespan.
Front Side Marker Light & Rear Side Marker Light: L-T10A(Amber)/L-T10R(Red)
800LM/set, much brighter than OEM halogen bulbs. It's necessary and easy to achieve to add a modern appearance to your truck by replacing stock halogen bulbs with this LED bulbs. No need any modification, just for plug and play installation.
License Plate Light & Interior Door Light & Map Light & Dome Light & Trunk Light: L-T10(White)
800LM/set, 6000K pure white. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Back Up Light: L-T15(White)
1400LM/set, 6000K bright white. Lasfit uses high power 3030 SMD LED chip to produce peak brightness output and built-in Constant Current IC driver to ensures reliability. Equipped with CANBUS system, will not cause "lamp out" errors. Plug and play design.
Vanity Mirror Light: L-31MM
6000K pure/ cool white light. Festoon bulb. High quality 3030 SMD LED chips. 1.22'' in length, 0.47'' in width. Non-polarity design, plug and play. Efficient aluminum heatsink system for safe installation and usage.
LASFIT
Colorado
Dec 21, 2023 10:12 PM
LASFIT
Dec 20, 2023 10:24 PM
LASFIT
Nov 22, 2023 9:53 PM
LASFIT
Colorado
Nov 21, 2023 12:45 AM
LASFIT
Sep 5, 2023 9:30 PM
