2016 Equinox thinks the key is in the ignition when it isn't
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
Sometimes the door chimes after I park the car and remove the key from the ignition. When this happens the driver side door will not stay locked using the key fob or the control in the door. The only way it will lock is to manually use the key on the outside of the door. After I return to the car, I have to unlock the car using the key (not the key fob) and when I open the door, the door starts chiming. It seems to me that the car thinks the key is still in the ignition even after the key has been removed from the ignition. Has anyone else had this problem and if so, what is the fix?
