2017 Chevy Equinox 2.4L Electronic Steering Whine
Hi everyone. I've been driving around a 2017 Chevy Equinox LT 2.4L and noticed that the steering whines slightly now. It's been a gradual thing that I was keeping an ear out for.
So i did some quick research and found that it had Electronic steering with a power assist motor attached to it. Didn't realize that newer electronic racks even had motors.
I also noticed that you can either buy just the rack and pinion with no motor, or it with the motor, but with the motor costs almost 800 bucks vs just 200 to 300 for the rack itself. Is there any way to narrow down if the issue is with the motor or the rack/pinion itself to replace the individual component? Can either one be replaced by itself or do they have to be replaced as a whole unit?
Also, according to the Haynes manual, it says that the catalytic converter and rear transmission mount need to be removed to ultimately take out the rack. Can the rack or power assist motor be removed without doing these? It would just make things a lot easier.
Just going to keep an eye on it for now and see how bad it gets. And listen to it underneath it one of these days.
comp (August 26th, 2021)
It's all electric, so i doubt there's any hydraulic fluid in there. Maybe some oil for the power assist motor, but not entirely sure. And not sure if there's even a way to change it if so.
There is nothing like doing half of the job. The other half will wait for the worst time to cause you problems.
If you are contemplating replacing the rack do the whole job and do it once.
