Help! I was bleeding my coolant system. I loosened the bleeder screw up too much and the pressure sent it flying. I’ve tried every terminology I can think of to find a replacement. As you will see in the picture I have one that is kind of working as a band aid but I need the correct replacement part.
You couldn't find the original? If not online, a junkyard should have one, if you look. Car manufacturers tend to use the same parts on different vehicles, as it keeps the inventory down, and more efficient, saving them money.
I would think they are some wierd metric pipe thread which would be hard to even find a temporary plug. My past experience with them is they are made of brass and when closing them too much force will snap them off!
