BURNED UP 2 A/C Clutches
Hello, I have a 2011 Equinox 2.4L. The A/C Clutch burned up and the Radiator Fan will not come on. I put a 2nd Clutch in and it burned up as well. The Radiator Fans high and low speed relays are good and the fan will come on if I bypass the relays. The A/C Compressor has power to it, if I bypass that relay as well. All fuses are good also. It seem that there is something that will not allow all 3 of these relays to get power. Any ideas? Thanks, Jon.
