Canadian work like U.S.
Can a 08 Canadian Nox. Headlight control be programmed to work like a U.S. Model? I have access to a Tech II scanner.
The U.S. models can override the auto light function. If you are driving at night you can move the selector to the parking light position and the headlight will turn off and the parking light stay on. Or you can shut them off completely if you chose. In Canada this can only be done with the transmission in the park position. When in drive, we cannot override the auto light settings.
I'd guess that this feature is part of the the BCM's programming and cannot be changed by itself. It may be possible to re-flash the BCM for a US setup, but your buddy with the Tech-II would need find out for you. Furthermore, if you reside in Canada it may be illegal to make such a change, so he/she may refuse to do it as a result.
Unless you have a really good reason to make these changes, I don't think it would be worthwhile to pursue them..
The only reason I could think of to shut off the headlights while driving would be to flash headlights at a semi that is ahead of you to inform them it is ok to merge into your lane. I seldom find myself in a situation where this would be helpful though.
