CV Axle 2005 Chevy Equinox
Had a broken CV Axle. Purchased it from Advanced. The ToughOne's are too short. Buyer BEWARE!
Last edited by ChevyEquinox; August 7th, 2013 at 10:50 PM. Reason: Problem resolved.
news to me. Haven't seen this ever in the shop I work at.
not really sure how a cv boot slips? Why would you have to touch the band clamp to replace a hub assembly?
What do you mean there is no ABS support? Are you referring to a spot to clip the abs sensor connector?
Yours seems to be an isolated case for this issue. I've never heard of it before with the Equinox/Torrent.
Is your Equinox AWD or FWD? Which CV axle are you having trouble with? Which boot keeps separating (inner or outer)?
An educated guess is that the front passenger's side CV axle is the one you are having an issue with. I'm thinking that the previous owner replaced it. I suspect that when they did, they installed the wrong axle (too short) and stretched it to make it fit. The original setup used a shorter CV axle and an intermediate shaft at the front passenger side location. There is a replacement axle made by AC Delco (p/n 22718646) that is the correct length which replaces the original setup and allows you to remove the intermediate shaft setup.
Thanks, thats what i was trying to get at ruley73....cv separation? Hard to make a suggestion with a vague description.
I'd sell it too...putting the same part without fixing root cause...the 4th "broke axle" is just a matter of time. This is not the car's fault. The symptom not the problem is getting fixed.
2005 Equinox Axle falling off
Any idea why a CV Axle Shaft would keep falling off? A friend installed a new one for my daughter and it keeps falling off. They tried lock sealing the bolt just incase it was coming loose and it still fell off. A friend said it was a C Clip and installed one. Not sure if this is going to fix the issue or not. If a "C-Clip" was needed, why wouldn't one have come with the new axle? Thank you in advance.
Sorry if this is not where I should have posted this but I am new and can't figure out how to start a new post. Thanks.
Hi, i didn't see a response to my question below. Any suggestions? Thanks in advance.
Any idea why a CV Axle Shaft would keep falling off? Front passenger outer end. A friend installed a new one for my daughter and it keeps falling off. They tried lock sealing the bolt just incase it was coming loose and it still fell off. A friend said it was a C Clip and installed one. Not sure if this is going to fix the issue or not. If a "C-Clip" was needed, why wouldn't one have come with the new axle? Thank you in advance.
