demarreur a distance equinox lt 2007
je viens d acheté il y a 3 jours un equinox lt 2007.
démarreur a distanche a fonctonner une fois .
j ai suivi le manuel du proprietaire ; appuyer une fois sur doorlock ,
parking light allume une fois ensuite j appuie sur bouton ,demarreur
parking light allume une fois mais l auto ne demarre pas.
quelqu un a t il une idée du probleme ??? merci a tous
I come d bought 3 days ago an equinox lt 2007. Starter has distanche has fonctonner once. J followed the manual of the proprietaire; support once on doorlock, parking lot light lights once next j leans on button, demarreur parking lot light lights once
but car l not demarre. does quelqu one have t it an idea of the probleme??? thank you has all
this is what Freetranslation.com had to say
Sorry but I'm tapping in english but don't know how you get it in French... Here is my probem:
I just bought a 2007 Equinox LT 3 days ago. The remote starter did work that day... since than I have problems. I did everything indicate in the manual (activated starter in the vehicule informations center and put back factory settings) I also changed batteries in the remote. It works once... than nothing again..... Here whats it does:
When I press door lock, parking lights flash one time, than press start button one time (at less 5 seconds) parking lights flash one time but car do not start. Can someone help???? Thank you!
Turn the vehicle on, while in park, and press the button with a car and "i" on it. It should be between the roadway button and the check mark button.
Texcowboy
January 19th, 2011 7:57 PM
