Does 2.4L Equinox 12 model have EGR Valve? Where is it located? Stabilitrak Issues!
Having the Stabilitrak issues and it appears after watching many videos the EGR may be bad?
Car will run rough, or not start.
Already replaced the battery and had the alternator tested. Both check.
Now replacing the coils and spark plugs. Both check.
Does the 2.4L have a Exhaust Recirculation Valve? I cant find a part # or schematic anywhere online???
Only 1 reference stating it doesn't have one, right?
What else could be causing the car not to start, idle rough?
Many Thanks!!!
Many Thanks!!!
The 2.4L doesn't have an EGR valve. The EGR valve wouldn't be the cause of your problems even if your engine did have one. I'd suggest checking fuses, inspecting the engine wiring, and checking your ground connection(s) between the engine and the chassis. If your Check Engine Light is on, have the vehicle scanned for any troublecodes.
