Driver side door doesn't lock
Hello,
I am having issues with the automatic locks on the fob AND lock switch on drivers side door in my 06' equinox. his happened a year or so ago (I know, long time to let it slide). Every other door works, when I put my vehicle in drive, all other doors but the drivers side locks and same with park, all unlocks (but the drivers side was already unlocked lol). The door switch on the passenger side, works to lock and unlock all doors, except drivers. And lastly, the key fob works to lock and unlock all doors.... but the drivers.
Have any of you had the problem and found a solution or even know what the problem may be?
Any help is appreciated, TIA!!
Jordan
Jordan
Hello,
Jordan
Jordan
broken wires in the door jam A-pillar are common. pull back the rubber loom and inspect. Or check for power and grd to the lock actuator...if power and grd are at the actuator...the actuator is bad. if no power and grd...check the door wiring.
I probably have replaced 10+ of the door wiring harnesses.
