Excesive Idle 2005 Chevy Equinox LS HELP HELP
PLEASE PLEASE PLEASE help!!!. I have a 2005 chevy equinox LS with 99,000 miles on it. I’m having high idle/shaking when the car is in drive but stopped (at a light for example). I’ve had replaced the Throttle Body, EGR Valve, Motor Mount, 02 Oxygen sensor (upstream), Tune up, and spark plugs replaced twice. There are no lights on the dash to indicate a problem.. I’m at a loss as to what could be the problem now… PLEASE PLEASE PLEASE help me find the issue
Does it idle high in park or neutral without applying the brakes?
Also, when the EGR valve was replaced, did they install the newer design EGR valve? If so, was the PCM recalibrated?
It actually Idles both ways. At first it was just when in drive applying the breaks. Now it also does it in park. Also the EGR Valve was replaced with the newer one. I had to replace the entire EGR Valve including the hose because of the new design.
Remove the engine cover and make sure the nipple that screws into the upper intake for the brake booster hose is not damaged and is properly tightened.
Cindinw
January 25th, 2018 8:10 PM
Werstsiderkg
September 17th, 2017 9:12 PM
Taylor1
December 5th, 2010 4:39 PM
