Fog Lights
Fog Lights
2014 Chev. Equinox 4 Cyl Gas LT,
Did not come with factory fog lights. What will I need to install? Is the wiring needed to install already there or will I need a whole new wiring harness?
Joe
Joe
Foglight kit comes with lights and external wiring. Internal wiring is already in vehicle. There is a turn signal switch change out. There is some programming has to be done are for lights to work correctly.
I added my own fog lights and just made my own circuit and added my own on/off switch. Very simple to do and you don't have to change or modify anything. Just make sure you put a fuse in the circuit.
install fog lights
