P228D code 2012 equinox
I am reading a p228d code. Vehicle stalled and won't run I replaced fuel pressure switch and hp fuel pump. Still can't get rid of code and still won't run. Any one with suggestions please reply I'm going nuts
P228d
What is this reply based on? The code doesn't mention it. Id hate to throw more parts at it on just a whim. I'll try it but would like to fortify assumption first
should be the same since that was the entire idea with OBD II in the first place. When I was young we had no onboard disagnosictics, so one used intuition quite a bit..
Have you confirmed that the primary/supply fuel pump in the fuel tank is actually running?
Is P228D the only code you are getting?
The high pressure fuel pump is driven by the intake camshaft, so a timing issue may also cause this code.
