Parts Compatibility
All wheel bearing/hub assemblies, and both rear CV axles for AWD models are the same for all 2005-2006 Chevy Equinox, 2006 Pontiac Torrent, and 2002-2007 Saturn Vue.
The front CV axles have a shorter, more complex compatibility list. The front left CV axles are all the same for all 2005-2006 Chevy Equinox, 2006 Pontiac Torrent, and 2002-2003 Saturn Vue V6 models. The Saturn Vue year range is shortened because only the 2002-2003 Saturn Vue with the 3.0L V6 engine uses the same transaxle as the others (Aisin AF33 5-speed auto). The 2004-2007 Saturn Vue V6 models came with a Honda-sourced engine & trans, so they use different parts.
The front right CV axle is more complicated because some of the previously mentioned models used a 2-piece front right axle with an intermediate inner shaft and outer CV axle, but others used a single piece front right CV axle. GM now says to replace the two-piece CV axle with the longer single piece CV axle (AC Delco p/n 22718646). GM has discontinued the 2-piece design parts, but both designs are still available in the aftermarket, so one needs to be careful when shopping for the front right CV axle for these models.
Thank you
The thing is my son just totaled him about my 06 equinox but I still have brand new in the box both rear hub assemblies the outer part of the CV axle and hub assembly for the front passenger so I'm going to try and get around the same model car or at least when the parts will fit the only ones that actually put on with the CV axle in the hub assembly for the driver side
You should be able to return those parts and get your money back unless you've been sitting on them a while. Even then, if you bought them from a local brick-and-mortar parts store, they'll probably at least give you in-store credit for them. Just my $0.02.
parentsmag
January 13th, 2010 8:57 AM
