Permanently Removing Start/Stop Technology
Hello Guys. I am new to this forum just having bought a 2021 Equinox (in Canada).
Is there a permanent method to undo the start/stop tech ? With my old Jeep Ccherokee, a pressure switch under the hood could be uncoupled and it turned it off.
What about the Chevy vehicles?
We have a 2018 Chrysler Pacifica minivan with stop/start. I just disconnected the negative cable from the small auxiliary battery to disable it. The only side effect is that this causes a warning message to pop-up for three seconds at every engine startup and and the corresponding warning light remains on after the message disappears. The light isn't much of a distraction at all. This won't work with your Equinox, but it should work on your Jeep Cherokee if it has two batteries like our Pacifica does.
https://www.smartstopstart.com/. Her is a link to solve your problem. I installed this on my 2019 Equinox and works perfectly.
tech2 (December 26th, 2020)
![Thumbs up](https://chevroletforum.com/forum/images/icons/icon14.gif)
Comment about the money saved with the auto shut off on a 2019 Equinox versus the replacement of the starter:
Rate of gas consumed at idle for a 2.0 engine: .16 gal/hr. = 20.48 oz./hr.
Hours at idle to equal one gallon of gas consumed: 6.25 hrs./gal.
New starter installation cost: Average $485.00
Estimate of cost of a gallon of regular gas: $3.00
Number of hours with engine shut down to equal the cost of the starter replacement: 161 hours
Put your transmission in the L position and push the + symbol on top of the transmission shifter until you see a 6 or 8 (maximum number of shifts your transmission has) appears on the dash. Your vehicle will drive normally but not automatically stop the engine each time you come to a halt. This auto stop feature is not worth the wear and tear on your car. If it is not the starter that wears out first it will be your battery from so many starts. Each time you remove the shifter out of the L position you will have to reset with the + on top of the shifter while in the L position. Not as inconvenient as you may think.
Any other starter failure leaves you stranded in a safe parking space but stop/start leaves you stranded while you are driving and usually in the middle of a busy intersection.. #$%! that. Even if it saved an extra dollar on gas each time you use the car (and it doesn't) it's not worth that risk. It was about $1200 to replace the starter and second battery on my 2015 Malibu so no savings at all in the long run and one big bill all at once. Before that I NEVER had a starter fail on a modern car, not since the 1970s anyway and that was only because my first car needed a tune up and was hard to start. Stop/Start is a bad idea and not safe when it causes a failure.
tlsmith663
March 19th, 2018 6:24 PM
