Rattle when going over bumps
I have a 05 equinox awd. Whenever I drive over any slight bump, it feels like my car is going to fall apart. Can only feel in front and not back. What could be causing this?
The next thing to check are the rear bushings in the front control arms. GM issued a TSB applicable to 2005-2007 Equinox that addresses rattling in the frond end when driving slowly on rough roads. The TSB says the fix is revised front control arm rear bushings and specifies part number 25823014 for the revised bushings. That part number has since been replaced by part number 25919637.
The ball joints could be bad, but those usually cause a popping sound when accelerating hard from a stop or braking hard.
One last thing could be a worn intermediate steering shaft (the part that links the steering column to the rack). If the noise goes away when holding steering pressure in either direction when going over bumps, this is probably your problem and the intermediate steering shaft assembly would need to be replaced because the U-joints are not serviceable.
