Service Stabilitrak, Traction Control lights ON, alone with check engine light...
I have a 2008 Equinox I bought used 2 years ago. The stablitrak light came on without any check engine light. At the same time the car would not let me shut the ignition off completely and the key would not come out. It was a Friday night and my mechanic is not available until Monday. The battery finally died since the dashboard remained on with the key in the ignition. I have never even heard of this problem. My passenger seatbelt connector was just replaced last week. Could this be related? Why won't it let go of the key?
After you get your new battery (or the old one recharged), make sure the shifter is fully placed in the Park position. If the factory battery has not yet been replaced I would strongly suggest getting a new battery since the factory battery will not last much longer anyways.
Your passenger seatbelt connector and related circuits would not affect the operation of the ignition key.
Shifter linkage can be adjusted to accommodate the shifter going into park. If it happens again, try slamming the shifter into park and that should release the key.
Have you run codes? If so list them here or research them online to find out what the problem is.
Sounds like the dealer wants to make some fast cash.
John
John
John
John
Originally Posted by ruley73
Most likely one of the wheel speed sensors is bad or the wiring going to one of them is bad. A visual inspection of the wiring and using a scan tool that can read ABS codes are the only ways to properly diagnose the problem.
No codes came about from it and I have tried slamming it in park and it didn't help. The problem with the shifter is the button not extending fully. So instead of spending money on it, all i do is listen while i push the button til the clicking sounds right and the key will rotate and be able to removed. The shifter and the power steering are both not covered under the warranty
have you tried yanking the steering wheel back and forth in teh lock position while trying to remove your key? that usually does it in most cars. i think i had that problem in the equinox before.
