Will 114.3 x 5 fit on 115 x 5
I have searched quite a bit on the issue of weather you can put a wheel that has a bolt pattern of 114.3 X 5 on a chev, (specificly my equinox) that has a bolt pattern of 115 X 5. It seems that it depends on who you talk to you get a different answer. I recently went into a local auto parts store that sells after market wheels. I simply asked them to look up my 07 equinox and see what was available in a certain brand I was interested in. They had a few different styles that showed up for the equinox and when they brought the boxes out they all said 114.3mm X 5 on them, they doubled checked the part number and it was correct, knowing this was not my exact bolt pattern I checked into it first even though they told me they should work just fine. I know of people with grand prixs and other such cars that have done just fine with this bolt pattern but i am still hesitant to do it myself. As well I have called a few different wheels manufactures and some of them don't even make a 115 X 5, they told me that same thing my parts store did, they use the 114.3 x 5 for people that want 1 115. I guess I am just looking for a little feed back on this. Any feed back would be great
thanks,
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
It would fit, but the bolts will be off-center. The lug nuts will not seat correctly and over time you would have the possibility of the lug nuts backing off.
I would not recommend using 114.3 on 115 bolt pattern.
MrChevy
December 28th, 2009 9:52 AM
Cavigurl85
August 16th, 2006 8:33 AM
