06 Express van
Old June 9th, 2006, 8:26 PM
59Fins's Avatar
Default 06 Express van
I have a Chevy Express van for my work, I am in and out of it all day.
But I use the inside as an office, desk and all, I live in the Phoenix metro area (hot)
when I sit for any lengh of time, the temp guage climbs an the A/C slowly fades away.
I took to dealer for a solution with no luck, they say it is not designed to idle for periods
of time and keep the interior cool, well I am looking for help/ suggestions, there are several
other 06 Express vans in our "fleet" and some say they have the problem and others do not.
If I open the hood when idleing it appears to help sometimes, and others I am not sure, it
is really starting to heat up here in PHX, was wondering if a external electric fan would work
or help and if so, where do I get one and what type, or is there a better solution.
If the van starts to warm up and a/c starts too shut down sometimes I will rev the van up a
little and it will cool down, I cannot believe there is not a solution.
My last van was a winstar and it kept cool all the time at idle.
5.4? litre v8 auto, w/rear a/c
Bill
Old November 29th, 2006, 7:22 PM
teamelement2006's Avatar
Default RE: 06 Express van
check your coolant level fill it up if its low
Old November 27th, 2011, 1:31 AM
rickc's Avatar
I find it hard to believe, but i will state the very obvious:
Cars are not meant to be used in the way you are using it, plus you are killing our planet. find a shady tree for cryin out loud.
if you still see fit to destroy the earth to make a living, i would recommend
Park in the shade, it will help.
install a window air conditioner and find a place to park where you can plug it in - then turn the damn engine off!
you must be made of $$$ to run your air conditioned metal box on gasoline....crazy
Express
October 30th, 2012 10:44 AM
shulamite
September 20th, 2007 3:36 AM
hurleysurf24
September 11th, 2007 10:41 PM
Quick Reply: 06 Express van
