'16 Dome light issue
Old Aug 24, 2017 | 11:26 PM
StanVan's Avatar
15 Year Member
Default '16 Dome light issue WTF Now?
I hesitate to ask this, as I know what the first thought will be. My dome light doesn't come on when the door opens. I know about the override switch(not my first Chevy that has this feature). It's still under warranty, so I'm not asking for a solution. I just would like to know if this is a known thing. The switches work, as the chimes go off appropriately, and the light comes on manually. It's quite annoying, but I'm very busy for the next few weeks. Knowing may help it be less annoying.
Old Sep 10, 2017 | 10:38 PM
ChevyVanMan's Avatar
Where do you think the over ride switch is ? I had same problem on mine, thought I knew too..
Thank you
Kenny
Old Sep 11, 2017 | 6:58 AM
Twscarp's Avatar
This is where the switch is on my 2008 Express 1500, from the owners manual.
Attached Thumbnails '16 Dome light issue-screen-shot-2017-09-11-7.52.42-am.png
Old Sep 11, 2017 | 6:27 PM
Thought it was 2016, send a pic of your switch and see if it is the same..
Thank you
Kenny
Old Sep 11, 2017 | 7:18 PM
Twscarp's Avatar
Like the manual says: "The dome light override button is located next to the exterior lamps control."
Attached Thumbnails '16 Dome light issue-screen-shot-2017-09-11-8.08.11-pm.png   '16 Dome light issue-screen-shot-2017-09-11-8.08.52-pm.png
Old Sep 11, 2017 | 7:33 PM
canucklehead's Avatar
The on off part of that switch is the upper half of the bezel. The little **** only controls the dim.......the upper half flexes and is the switch.
Old Sep 11, 2017 | 8:10 PM
Twscarp's Avatar
Good job canucklehead, I didn't know about the push to depress the top part to turn off the dome lights, push again and the switch comes out and domes come on. The little **** (stalk), will also turn on the dome lights, if rotated all the way clockwise. You have a 2014 Express, is yours the same as mine?
Attached Thumbnails '16 Dome light issue-screen-shot-2017-09-11-8.56.07-pm.png
Old Sep 11, 2017 | 8:30 PM
Hey you found it..
Thank you
Kenny
Old Sep 11, 2017 | 8:50 PM
Twscarp's Avatar
Hey you found it..
Hmmm, I knew where it was located, is your 2016 the same? That was the question.
Old Sep 11, 2017 | 9:24 PM
Yes, I was replying to the original poster.. Chevy dropped the ball on that switch, it took me about 2 hrs to figure it out..
Maybe Stanvan will find it now..
Thank you
Kenny
