2000 express crank/no start
Old May 21, 2023 | 3:45 PM
Sometinaintright's Avatar
Post 2000 express crank/no start
Hello peeps...So I picked up a Express 3500 5.7 cutaway. Started working on my new van (yeah new to me). Anyway I was installing a new radio and the key was all messed up could not get the acc to work so i installed a new key/lock cylinder. Started a few times was good. I just was buttoning up the dash and went to start and it starts for only a little bit and quits. I smell gas so its not the pump. So im thinking its the security system is a fault. I have no codes cuz the batt was been disconnected. The Security light does not light up at all. I think that's where the problem lies. I disconnected the new stereo and plugged bank in the old. No change, I put back in the old key/lock cylinder No change. I have been looking for somehow to check components before I throw the wallet at it. I believe the system I have is the Pass Lock. (There is no piece of rice in the key). I have checked all the fuses, the 20 amp to parking brake fuse was blown. soon as put that in the dash lights for night driving work. I just went and looked again trying to start and there are no engine lights that fire up right away also. I also wiggled the wires and looked for lose connections. The wiring has not been butchered. I drove this truck only for one hour so i dont know what lights are supposed to flash when you turn the key to start. Is there another fuse box? Maybe a relay I could check? not sure where to go from here?
Old May 21, 2023 | 4:15 PM
smell test is insufficient. Pump needs to maintain a certain pressure. Measure it with a gauge.
The Security light does not light up at all.... trying to start and there are no engine lights that fire up right away
You mean not even during the power on lamp test? You may have an issue in the ignition switch, cluster or wiring harness (grounds etc.)
A diagnostic scanner would confirm that.
two. One under the hood, and one under the driver's seat.
Old May 21, 2023 | 5:28 PM
Arrow Thank you for the suggestion
Yes, I Get no Mil lights, It did before, is there a inline fuse possibly or a ground to specific to look for under the dash. I seen a utube vid of a guy re grounding the underside of his van.
I checked all fuses under the hood and at driver kick panel.
Old May 23, 2023 | 8:38 AM
Talking Follow up-Got it
Well figured out the problem, I had the cluster checked out and that was fine, went back and replaced every fuse in the kick panel and under the hood. No change, I probed every fuse with light and seemed ok. Figured I would try a volt meter on every one.Sure enough 3 of the 10's the fuse were bad from brand new. Replaced those and truck started right up. Note: I did not even have the cluster hooked up, put that back in and all lights/gauges work. Hopefully this will help someone else out.
Old Jun 5, 2023 | 6:36 AM
phantomjock's Avatar
This is the 3rd or 4th NO CRANK/No-Start I've seen posted in the past several weeks. What is going on? Sunspots?
You didn't mention which fuses you found as a "problem" in the underhood fuse box.
A fellow posted on FB a similar situation. He found the "culprit" to be the start/Crank fuse.
It is number 64 in the following diagram (disregard the ABS fuses highlighted - - I'm trying to solve that damn dash light!)
Cheers - Jim
antoniosc79
1988 - 1998 (GMT400)
May 23, 2023 8:44 AM
vfvaughn
Jan 23, 2016 4:16 PM
dav38spl
Aug 5, 2014 7:33 PM
Jesse_225
17
Sep 1, 2012 6:12 AM
BobbyW
Jun 10, 2010 11:38 PM
