2005 Express 2500 flashing engine light nightmare-New Member
#11
#12
I just checked the fuel trims
At idle:
Short term bank 1 fluctuates between 0 and negative 3
short term bank 2 goes between negative 2 and negative 3
long term bank 1 is 101
long term bank 2 is 12
When RPM brought to 2500
short term B1 goes as high as 2
Short term B2 goes as high as 3
Long term B1 is 8
Long term B2 is 7
Can you break this down for ne and tell me what I'm seeing here? Thanks
At idle:
Long term B1 is 8
Long term B2 is 7
#13
At idle:
Long term B1 is 8
Long term B2 is 7
At idle:
Long term B1 is 8
Long term B2 is 7
ST B1 0-3
ST B2 1-3
LT B1 5
LT B2 7
2500 RPM
ST B1 negative 1 to 5
ST B2 0-5
LT B1 5
LT B2 5
#14
At idle:
Long term B1 is 8
Long term B2 is 7
At idle:
Long term B1 is 8
Long term B2 is 7
#15
#16
#17
ok so it starts high and then settles down a bit. LT trims could be lower.
Is the air filter clean? Try cleaning off the MAF sensor with some spray cleaner.
#18
Air filter is clean and new. Just installed a couple days ago. I will try cleaning the mass air flow and see if that does anything
#19
Hete js something odd though....if i monitor nisfires on the scanner and slowly bring the rpm up to 2500, there are no misfires BUT if I rev the engine slightly, there are some misfires on 1,2,6, 8 and sometimes 7. Along with this there is a "sucking" sound when revving the gas slightly. I have the doghouse off and I swear I can hear a faint vacuum leak at idle. I've sprayed a little brake clean around and no change in rpm. I just can't seem to find it.
any ideas about these issues?
#20
