Brake Lights
1999 express van,
When the lights are off, the brake lights are work fine. When the lights are on, the brake lights are on, when u press the pedal the lights go off. The center light above the door works correctly? Any suggestions?? Thanx, Mike :D |
RE: Brake Lights
Trailer wiring ??
RE: Brake Lights
I had the same problem with my van, 2000 express 1500 conversion.
it seems that the wires entering the bulb sockets get loose or they rot from moisture after a few years, I jiggled and pushed them into the sockets, then tested them and the problem went away, mine seem to be working fine, but i would recommend replacing them with new bulb sockets....hope this helps. |
