Brake Lights
Old July 19th, 2007, 6:40 PM
shanael1's Avatar
Default Brake Lights
1999 express van,
When the lights are off, the brake lights are work fine.
When the lights are on, the brake lights are on, when u press the pedal the lights go off.
The center light above the door works correctly?
Any suggestions??
Thanx, Mike
Old July 20th, 2007, 9:38 AM
golfer's Avatar
Default RE: Brake Lights
Trailer wiring ??
Old July 27th, 2007, 3:26 PM
strictly chevy's Avatar
I had the same problem with my van, 2000 express 1500 conversion.
it seems that the wires entering the bulb sockets get loose or they rot from moisture after a few years, I jiggled and pushed them into the sockets, then tested them and the problem went away, mine seem to be working fine, but i would recommend replacing them with new bulb sockets....hope this helps.
PatrykKoul
April 26th, 2023 9:14 AM
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
cowboys
December 18th, 2006 12:28 AM
Quick Reply: Brake Lights
