woodhooks |
August 12th, 2020 5:57 PM |
dies and stabilitrac blinks
Help! Please! i have an intermittent problem where the "service stabilitrac" light dings once and the van dies .5 seconds after. No codes. i then put it in nuetral or park and turn the key forward, sometimes it starts right away, other times i have to turn the key off before starting it and it starts up again. it has happened while in park, and while at a stop light in drive. it happened driving 70, where the stabilitrac light blinks but that time the van did not die or sputter. the stabilitrac light never stays on. Is this a common issue at all?
i saw a video of a guy on youtube who found a 12v wire that was aftermarket for a fuel lift pump, and it was shorting out on the block; however, i have no aftermarket items except for trailer wiring.
I plan to crawl under and check every little wire, but I was hoping someone had experience. We are about to embark on an 1800 mile journey with a camper and I would like to get this figured out. I always travel with a full set of tools.
